Fein Multimaster Maintenance?
Forum topic by Stevedore posted 01-18-2019 05:53 PM 262 views 0 times favorited 5 replies Add to Favorites Watch
View Stevedore's profile
Stevedore
82 posts in 2293 days
01-18-2019 05:53 PM
I have a Fein Multimaster that’s about 7-8 years old. No heavy use, just typical home repair/improvement stuff like trimming molding, detail sanding, etc. Probably the most use it’s seen in one session was earlier today when I spent an hour or so with it cutting away the granite top on our kitchen island. (I cut the silicone holding it down, not the granite itself!)
I’m wondering if these tools need any sort of lubrication to keep them in good shape. I don’t see much on the web about disassembling them for greasing, etc., & Fein just says to take it to an authorized service facility.
I guess what I’m most concerned with is the head with the gearbox, eccentric, or whatever is in there doing the oscillating motion.
Anyone with any related experience?
-- Steve, in Morris County, NJ
5 replies so far
5301 posts in 2761 days
#1 posted 01-18-2019 06:15 PM
Mine is 16 years old, and I haven’t done a thing. Still works great. The use it’s seen is along the lines you described.
Stevedore
#2 posted 01-18-2019 08:15 PM
Thanks Fred, that’s good to know. Sounds like I can just blow the dust off & keep using it.
View Kazooman's profile
Kazooman
1272 posts in 2220 days
#3 posted 01-18-2019 08:33 PM
Mine is at least twenty years old and still going strong. I still have the original instruction manual and the only maintenance they suggest is to use a brush to clean out the cooling air slots. I use mine all the time for things like cleaning up handle slots on cutting boards after routing them out with a bowl bit. Works great.
View Bob5103's profile
Bob5103
117 posts in 1101 days
#4 posted 01-18-2019 08:47 PM
I have had mine for about 10yrs, and an in late November last year it quit. I took it apart and cleaned it (it was filthy)and found a loose connection. Tightened the connection and it runs perfectly. It was easy to take apart, and I was amazed at the amount of junk, that had accumulated inside.
View SMP's profile
SMP
304 posts in 173 days
#5 posted 01-18-2019 08:50 PM
IMO, the best “maintenance” for it would be to use it every so often, to keep the grease from coagulating and hardening in one spot. That seems to be what happens first. Grease dries out in one section and stops lubricating the bearings and other friction areas.
