Caulk or wood filler
Forum topic by FrankD90 posted 12-01-2018 03:11 AM 569 views 0 times favorited 15 replies Add to Favorites Watch
View FrankD90's profile
FrankD90
4 posts in 77 days
12-01-2018 03:11 AM
Hello,
I’d like to preface this first post with I am very much an amateur woodworker (I use that term loosely).
Moderators please feel free to move this thread if it’s in the incorrect forum.
Onto my question,
I built a home bar in my basement and I am not sure how to remedy an issue I’m having with the bar top. Our bar top is made from 2×8x12’s from homedepot (God forgive me). So the edges of the boards were rounded or whatever that is called. So when you lay the 2×8x12’s next to each other they aren’t flush, there’s a slight bevel. So to fill this bevel we thought “Hey! Let’s fill it with wood filler”. Bad idea. Now the bar-top flexes just a little when bigger guys who’ve had too many lean on it. So that wood filler has cracked down the length of the top.
The top is stained and polyurethaned so re-filling with wood filler isn’t an option. I’d like to know if caulk would seal that crevice and offer a flexible, watertight seal. I can try to get pictures tonight.
I’d like to know if the caulk would work and if it is safe to apply over the polyurethane coat.
Again I’m not sure if this is the proper area so please correct me if I’m wrong.
Thanks for your patience.
Frank
15 replies so far
View Aj2's profile
Aj2
1983 posts in 2063 days
#1 posted 12-01-2018 03:48 AM
Ha my brothers name is Frank haven’t spoke to him in years. So my suggestion is to rip it out and start over.
And don’t use wood from the borg unless your framing a wall.
Find a local lumber yard and pic something suitable in the color you want so there’s no staining.
Ok
-- Aj
woodbutcherbynight
5865 posts in 2674 days
#2 posted 12-01-2018 03:55 AM
Did you glue the 2x’s together?
FrankD90
4 posts in 77 days
#3 posted 12-01-2018 03:59 AM
We did not, we initially were going to use epoxy glass but opted out for cost. I just want to fill the seams with something waterproof and was wondering if caulk would adhere to polyurethane on the wood?
woodbutcherbynight
#4 posted 12-01-2018 05:14 AM
- FrankD90
No, it will not stick. Neighbor tried this, results were I got asked to make new tabletop.
View therealSteveN's profile
therealSteveN
2024 posts in 839 days
#5 posted 12-01-2018 06:29 AM
Yeah just abutting 2 or more pieces of BORG lumber (2 x material) you WILL get a lot of movement, flex, and it will become more unstable with age. Even if the budget says you need to use BORG wood, laying up layers of plywood would be more stable. On that you could Hammer veneer a hardwood of choice on top, and get the look, you would just need to place a banding of solid wood over the edges to hide the ply’s.
BORG 2x lumber will be drying, and moving on you for ages, so placing any kind of filler there will just loosen, and come loose.
You can do a glue up of 2 x material, but it will be best to joint down the edge, then cut the other edge on a TS to get rid of the rounded edge, then glue them up. With that you really need to use care affixing this to your base, wood movement will tear up your pine, unless you allow for the movement, so on your attachment you need to use figure 8’s or make some wooden cleats to attach so it’s anchored down, but given a way to move.
-- Think safe, be safe
View WoodshopTherapy's profile
WoodshopTherapy
30 posts in 369 days
#6 posted 12-01-2018 12:13 PM
In my opinion, replace the top and chalk it up to a learning experience. I’ve had success using plywood as a bar top and edging the plywood with “bar rail” on the front side and 1×3 stock on the back of the bar. Plywood is stable and it won’t warp if properly supported. For example, and L shaped bar can have a 45 degree corner on the top, but an overlapping layer below that to support and stabilize the structure.
-- Scott Bennett - sharing woodworking knowledge at Home Improvement Woodworking
View Eric's profile
Eric
79 posts in 138 days
#7 posted 12-01-2018 01:12 PM
Unfortunately i have to agree, chalk it up as a learning experience.
Wood will move as it dries, the best prevention it to use some type of cleat when attaching it to a frame. Use of a plywood substrate will help, but you can still get srinkage.
I have found that building a table top for yourself, let the material climatize to your home. My ex hated it but I would slide the planks under the couch for a few months. It is not a perfect cure, but it did reduce some of the movement. But also joint the edges prior to glue up.
Good luck
-- Eric, Upstate South Carolina
View JCamp's profile
JCamp
906 posts in 815 days
#8 posted 12-01-2018 04:19 PM
Well u could go back with wood over top of it (depending how it’s made) and make it look better that way. Could be done with plywood or use tile or actual kitchen counter top.
-- Whatsoever thy hand findeth to do, do it with all thy might
FrankD90
4 posts in 77 days
#9 posted 12-02-2018 03:11 AM
FrankD90
4 posts in 77 days
#10 posted 12-02-2018 03:11 AM
Here’s why I cannot tear it all apart. I’m thinking I may inlay some wood to fill the gap.
Frank
woodbutcherbynight
#11 posted 12-02-2018 04:04 AM
Here s why I cannot tear it all apart. I m thinking I may inlay some wood to fill the gap.
Frank
- FrankD90
This will bring you back to a repeat of the problem to begin with. The wood you made it out of moves. You would need to route a channel deep enough and wide enough to put a inlay, with another kind of wood. Neither will move at same rate. In short time you will be back to square one.
View pottz's profile
pottz
4070 posts in 1249 days
#12 posted 12-02-2018 04:09 AM
abort abort will robinson abandon the ship,self destruct mode is now in progress!!!.seriously rip it out at whatever the cost,it wont get better,sorry I wish I could say something more positive.
View Chrisoferguson's profile
Chrisoferguson
1 post in 76 days
#13 posted 12-02-2018 06:01 AM
One of the earlier post nailed it.Framing lumber is only dried to roughly 19 percent mc,so it was going to shrink dramatically,hence the large gap.It should be 6-8 percent to use indoors,so in the future ,dry to appropriate mc,edge boards,glue up & anchor top so boards can move.Anything you do to patch has it’s risk.If money is an issue pull boards back up,lightly plane,edge,check moisture content,glue up & anchor appropriately.
View clin's profile
clin
990 posts in 1261 days
#14 posted 12-02-2018 07:05 PM
While I agree with all that has been said about problems using construction grade wood for furniture, caulks is cheap. In this case, get a dark colored caulk and give it a go. Might work fine, and last years, might not stick at all and you’re no worse off. Though I might try a small bit of the caulk first. Just to see if it sticks after it cures.
-- Clin
View TheFridge's profile
TheFridge
10833 posts in 1751 days
#15 posted 12-02-2018 07:20 PM
Well. If you’re gonna try it. I’d use acetone to clean the seams. It’ll probably hold pretty good until the wood shrinks and the caulk gets hard enough for the seams to split.
