Domino 500 or 700
« back to Joinery forum
Forum topic by TheStairMaster posted 03-23-2018 04:54 PM 700 views 0 times favorited 13 replies Add to Favorites Watch
View TheStairMaster's profile
TheStairMaster
23 posts in 331 days
03-23-2018 04:54 PM
Ok fellow woodworkers here we go;
All this time I worked with biscuit plate machine and kreg pocket machine in the later time of my woodworking adventures; now, I need advice should I dive into getting a domino or not? and if you guys can convince me on that, which one would be better, of course none is better if you consider pricing, but I hear they came up lately with these inserts that makes closet organizers a dream putting them together.
I watched you tube and see all these zelous-in front of the camera- woodworking guys (no disrespect intended there but that’s not how I do my business, I would’ve been out of business long time ago if I do all my work in front of the camera) swear by this domino toy; now, for my stairs branch, I really don’t need it, I can do away with biscuits when I glue the stair treads or any other boards together, but for all the cabinetry/closet organizers aspect, I think I might like working with one, or my guys for that matter.
Any advice?? The “in front of the camera” guys are welcome to join in too, lol.
Dan.
13 replies so far
View buckbuster31's profile
buckbuster31
256 posts in 781 days
#1 posted 03-23-2018 05:34 PM
I have the 500 and it does everything I need. I would love to have the 700 for certain applications though
View Loren's profile
10477 posts in 3913 days
#2 posted 03-23-2018 05:44 PM
Take a look at the Mafell duo-dowelers too.
View AandCstyle's profile
AandCstyle
3190 posts in 2522 days
#3 posted 03-23-2018 09:42 PM
Dan, the 500 only uses tenons up to 10 mm whereas the 700 takes 10mm and up, however, you can spend a few extra bucks and get an adapter for the 700 that permits the use of smaller tenons. I have the 500 and have found it a joy to use. More importantly, it is fast and accurate in cutting mortises right where you want them to be. HTH
-- Art
View TheFridge's profile
TheFridge
10833 posts in 1751 days
#4 posted 03-23-2018 11:04 PM
Have a buddy that does stair work. He loves festool gear.
View rizzo's profile
rizzo
74 posts in 1517 days
#5 posted 03-23-2018 11:10 PM
I have the 500 and it was a “game changing tool” for me. The precision that this thing provides is unreal. I have many festool tools, but this one is my favorite by far. So versatile. Also for “case construction” (like cabinetry and closet work) I highly recommend the “domi-plate” Its awesome for standard ply stock / stock.
https://www.senecawoodworking.com/products/domiplate-for-1-2-and-3-4-ply
I couldn’t be happier with this tool and for me at least I don’t miss the 700 capacity at all. The largest tenon that the 500 provides is more than enough for me for sure.
I use it all the time, for pretty much everything. It is just so darn easy to place a tenon in things. Face frames, boxes, miters (oh my gosh it is so nice for mitered picture frames), rail and stile etc.
TheStairMaster
#6 posted 03-23-2018 11:11 PM
- Loren
Thanks, I did but I need something stronger than the dowels system.
TheStairMaster
#7 posted 03-23-2018 11:13 PM
- TheFridge
thank you, I like festool too, bit pricy I guess, and….even that I was born in Europe, I can’t deal with the mm option.
Dan
TheStairMaster
#8 posted 03-23-2018 11:15 PM
- AandCstyle
Thanks for the detail explanation, I guess I might just dive into getting a 700 and get the adapter for the 500.
Dan.
TheStairMaster
#9 posted 03-23-2018 11:17 PM
I couldn t be happier with this tool and for me at least I don t miss the 700 capacity at all. The largest tenon that the 500 provides is more than enough for me for sure.
- rizzo
Thanks Rizzo; might eventually get the 700, but from what you are saying 500 also might meet all my needs.
Dan
View Drew's profile
Drew
350 posts in 3365 days
#10 posted 03-23-2018 11:17 PM
All depends on what you want it for. 500 for face frames, 3/4” material and for replacing a biscuit joiner. 700 can be used for that stuff but it is big, awkward and expensive. The 700 is good for mortise and tenon, doors and thick/heavy materials.
BTW, the 700 goes down to 8mm, not 10 as previously stated.
-- TruCraftFurniture.com
View bbasiaga's profile
bbasiaga
1243 posts in 2260 days
#11 posted 03-24-2018 12:23 AM
Many borderline applications, where you might wish you had a 700, can be addressed by using multiple smaller dominoes instead. Works great. If you were doing really big things, the 700 would be better. I didn’t go the 700 plus adapter route because the 700 was so much larger. I figured I mostly build furniture sized things which don’t need the extra domino size very often, and I’d just be toting the extra weight around all the time for nothing. Plus, its spendy already and the adapters are even more on top of that.
Brian
View Jon Hobbs's profile
Jon Hobbs
147 posts in 970 days
#12 posted 03-26-2018 07:36 PM
...should I dive into getting a domino or not?
It sounds like you’re using this in a professional setting. In that case, there’s really only 2 questions to answer:
Will it increase revenue?
Will it reduce cost?
If you’ll win more jobs by having a Domino vs. biscuits and pocket screws, then you should probably dive into getting a domino. If you can increase your rates because you have a Domino, then get one!
If you’ll reduce costs (jobs are done quicker resulting in less labor expense or stronger results resulting in fewer call-backs), then you should probably dive into getting a domino.
Otherwise, if you’ll win the same number jobs at the same price with the same labor costs, then why spend money on a more expensive tool?
-- Jon -- Just a Minnesota kid hanging out in Kansas
Jon Hobbs
#13 posted 03-26-2018 07:37 PM
It sounds like you re using this in a professional setting. In that case, there s really only 2 questions to answer:
If you ll win more jobs by having a Domino vs. biscuits and pocket screws, then you should probably dive into getting a domino. If you can increase your rates because you have a Domino, then get one!
If you ll reduce costs (jobs are done quicker resulting in less labor expense or better quality resulting in fewer call-backs), then you should probably dive into getting a domino.
Otherwise, if you ll win the same number jobs at the same price with the same labor costs, then why spend money on a more expensive tool?
